how to connect a double pole oven hood switch to mains
Posted: Thu May 17, 2012 7:38 pm
by chrisjoanne
Just after a little help please - nice easy one for someone :-)
I'm fitting a oven hood which has live and neutral (no earth) and the booklet informed me I need a 3amp fused double pole switch.
I've got a double and single socket where I would like the double pole switch to go but I'm confused how the connection should be made to the mains.
The double pole switch has 2 x live/neutral/earth (supply & load)
I assume it gets connected to the double plug but how?
Please see picture.
Cheers for any help.
Chris
Re: how to connect a double pole oven hood switch to mains
Posted: Sat May 19, 2012 12:17 am
Likely not permitted. The main way of wiring in the UK is what we call a final ring. One is allowed a single item spurred from the final ring. But only one item. The idea is the fuse in the plug or FCU will stop overload as long as there is only a single item. The only way to have more is if that single item is FCU in which case you can then add many more items after that.
I have looked at the restrictions to posting pictures on this forum and I am not prepared to jump through the hoops. If you want pictures try another forum.
Posted: Sun May 20, 2012 10:07 am
Hi, as this is a kitchen any wiring alterations/additions are covered by LA Building regs part p which effectively means not legal DIY.
However if as you say single socket is where you want the hood then why not change it for a
Fused Connection Unit(previously known as a switched /fused spur) with a 3Amp fuse these have the required double pole switch with 3mm breaking clearance and would be a non-alteration to the wiring so imho not reportable work.
regards Sparx
