Wiring advice for Heatmiser PRT-WTS
Posted: Sat Dec 07, 2013 10:38 pm
Hello all,
I'm about to replace a non thermostat timer unit for a Heatmiser PRT-WTS, but I wanted to make sure on the wiring connections before doing so.
https://dl.dropboxusercontent.com/u/90022289/IMG_0685.JPG
The link above is an image of the current timer wire diagram.
https://dl.dropboxusercontent.com/u/90022289/IMG_0686.JPG
This link above is for a photo of the current thermostat wiring.
https://dl.dropboxusercontent.com/u/90022289/IMG_0684.PNG
And the final link is the wiring diag for the PRT-WTS.
My thoughts are: Using the existing wires, L & N are obvious, and keep the live loop between L & COM. The only wire which gives me concern is the Brown wire currently in terminal 3; should this be the S/L connection going to NO1 on the PRT?
Also, because this is thermostatically controlled, are there additional connections needed to allow for thermostat switching on/off? If so, I'll need to get a sparky in for that. Hoping its just a straight swap out though.
Appreciate any help offered.
