Extending Ring Main for Sockets While Insulating under Floorboards
Posted: Fri Sep 11, 2015 2:17 pm
Hi - I am taking up floorboards in my home study to insulate underneath (can't stand another winter with cold feet). Thought I'd take the opportunity to spur off two more double plugs.
When I looked at the plugs first (before floorboards were up) was surprised to find what looked like one plug on ring main, and rest looked like spurs.
Now that I have the boards up I can see that someone at some point has cut into the ring main and using 30A connector strips as junctions spurred off each set of plugs (except one) and all wrapped in insulation tape on the ground underneath the joists. [In my loft I found similar when it came apart(!)]
I'd like to leave them alone - but I think they should be maintenance free junctions at least. And at the end of the day with the boards up its presumably simpler to just have a conventional ring circuit arrangements and no spurs at all.
I have traced the circuit to and from fuse box - so its definitely a ring.
It seems a simple enough task. It seems less likely to go wrong to wire it properly (and certainly less complex for the next person who needs to do something to it). And it would avoid the problem of creating inspection hatches for the junctions through the insulation. We are well away from kitchen, and bathroom. I am reasonably handy.
Any reason why I shouldn't do it?
