Converting a Single Light Switch to Two way Light Switch
greengrass
by greengrass » Fri Oct 30, 2015 9:01 pm
Looking at the images One shows the one gang light switch single way to left six feet away from the bedroom (good planning by an electrician) feeding ‘live’ to centre piece light and fan that have their own independent cord switches as shown. Left light right fan.
Existing switch wire old colours RED AND BLACK.
‘Er in doors’ has a fixation of two way switch substituting the existing single switch for a two way switch.
Wiring the existing switch wire to the new two way switch along with the two way switch cable as follows Red and Brown to common, Black and Black to L2 Grey to L1.
3 core at bedroom wall end Brown to common Black to L2 and Grey to L1 to match the other switch terminals. Leaving the centre piece cord light switch ON should produce a two way system from the two new switches and of course providing the centre piece switch is left on. The fan will operate on it own cord switch when required in summer. Hopefully its not a ‘clear as mud’.
Many thanks.
Re: Converting a Single Light Switch to Two way Light Switch
by ericmark » Sun Nov 01, 2015 9:40 am
The switch wires with single on/off switching go to Com and L1 with two way they go L1 to L2.
So the two switches are connected together like for like. i.e. com to com, L1 to L1 and L2 to L2 then the original switch wires go to L1 and L2.
There is some changes in numbering between makes sometimes labelled L1, L2, and L3 lowest number is com
[img]http://www.ericmark.talktalk.net/pictures/two-way-real.bmp[/img] I have tried to include diagram but never sure with this site what will work.
It is currently Mon Jan 13, 2025 7:50 am
