Underfloor heating-Electric.
Sparkydelux
by Sparkydelux » Fri Aug 10, 2007 8:00 pm
I have a query.I am to fit a provision point for underfloor heating in a new build and am a little uncertain if I should run it off an RCD circuit-being in the bathroom environment.
I will be mounting the thermostat outside the bathroom as to avoid mositure getting into the unit.The main supply for the underfloor heating is my main concern as I was going to take it off the nearest socket in the bedroom and fit it on a 13A fused spur (changing the fuse to the appropriate size of course). Both spur and thermostat will be outside the bathroom area.
I have read that the sensor has to be run in conduit.Is this from the thermostat to the electric matting?This house is a timber build with plasterboard finish and the flooring in the bathroom will be screeded and tiled.
Please could you guide me in the correct way as to not make a vital mistake.
Regards and thank you for your time and advice,
by sparx » Sun Aug 12, 2007 12:40 pm
Hi, I would use an RCD fused spur, the stat is usualy a capiliary tube which although not electrical is very easily damaged, & some types are a thermocouple also fairly fragile so If poss i would put in tube,
regards
SPARX
Sparkydelux
by Sparkydelux » Sun Aug 12, 2007 11:19 pm
Thanks for the advice.I'll make sure i fit it as follows.
Regards,
It is currently Mon Jan 13, 2025 6:27 am
