Changing a 2 Gang 2 way Dimmer Light Switch to Normal Switch in Living Room
Posted: Sun Dec 06, 2015 12:42 pm
Hello,
I am trying to replace a 2 gang 2 way dimmer switch in my living room to a standard 2 gang 2 way switch . The original had two dimmer switches, 1 for the main light and another to dim two wall lights. I think i would only need a two gang 1 way switch as there is only one switch in the room but the original dimmer was 2 way so i bought a 2 way.
I have copied the wiring from the original switch to the new switch. My problem is that only one of the wall lights will turn on. If i put bulbs in both lights the one furthest away from the switch will light and the other won't. If i remove the furthest bulb the nearer will light.
I am using LED bulbs in all the lights if that makes a difference.
Thanks for any advice!
