Replacing old BS646 Dimmer Switch with Modern 1G1W Switch
Posted: Tue Dec 15, 2015 11:09 am
Hi all,
Just moved into a house with an old dimmer switch in it, that requires a BS646 3A fuse to work. The fuse has gone, so was thinking I'd just put in a modern 1G1W switch. The front of the existing dimmer looks like this.
The wiring at the back (this house has the old UK wiring colours) has 2 reds in L1 and a yellow in Variable Load.
I'm thinking that all I need to do is put the two reds in the Common of a new switch and the yellow into the L1. Does this seem right to you experts?
Thanks!
Thanks!
