Run submerged waterfall pump without water, what will happen
herbolaryo
by herbolaryo » Wed Aug 15, 2007 10:42 pm
In the manual of the submerged waterfall pump...
It says, don't run motor without water.
If the motor run without water, what will happen to the pump? :?:
by sparx » Thu Aug 16, 2007 11:04 pm
Hi, depends how long! a few secs. to try out may be OK but pump relies on water to lubricate impellor/casing so if run for long dry then either siezes up or wears badly so poor performance,
regards SPARX
herbolaryo
by herbolaryo » Thu Aug 16, 2007 11:26 pm
The pump is located downstream the falls with a float switch to top off the water when it gets low due to normal evaporation of water. There is a pond at the lowest point of the falls where the pump is submerged.
However, there are unexpected electricity blackout which empties the whole pond. Since the float switch can keep up , during the time when electricity just came back, it sucks up air.
The pump sucking air only happen during occassional electricity blackout.
The humming noise occurred after that time eventhough I cleaned the filters and the motor "blade" of debri.
So what can be the cause of the hum noise in the pump and how to fix that?
by sparx » Sat Aug 18, 2007 5:50 pm
Hi maybe humming cause it can't sing??? sorry!
motor humming usually because it cannot spin freely, it may be still jammed too tight,
It is currently Sun Dec 22, 2024 9:56 pm
