Immersion Heater Switch and Finding Location?
Posted: Sat Oct 29, 2016 6:39 pm
by Zakjg
Hello,
I am trying to understand where the switch is for my immersion heater, and what the other switch is for? (Picture attached)
The bottom switch has off/on inscribed on it. The top switch just has fuse written on it.
The bottom panel has no switch and just has wires going to the 'controls' on the tank.
Please can somebody help me with understanding the two different switches?
Thank you,
Zak
Re: Immersion Heater Switch and Finding Location?
Posted: Sat Oct 29, 2016 11:00 pm
The top switch is called a fused connection unit and is most likely the supply to immersion heater, the next is a simple switch and I have really no idea what it might be for, the next box is likely the connection to central heating and the unit held to the tank is likely the sensor for the central heating so it knows when to heat the hot water.
Domestic most switches go down for on, not domestic is the reverse so anything falling on a switch will switch it off not on.
The immersion heater should have a thermostat built in, and also a cut out, if the tank is thermal plastic it should be non resetable but if the tank is hard plastic or steel then a resetable type can be used.
The thermostat in the immersion heater should be set above 66 degs C but less than the central heating so it will only cut in if central heating is not running.
Posted: Sun Oct 30, 2016 10:26 am
by kbrownie
To find out what you have some on site investigation is needed.
By the pictures we can only assume you have a fused connection unit protecting some part of the wiring nearby. If you could track the white cable heading off behind the cylinder, then we can determine what that is doing. I do hope it is an isolation switch, rather than a standard light switch as they are rated differently.And it could be under-rated.
Posted: Sun Oct 30, 2016 11:50 pm
by Zakjg
Hi all,
Thank you for the help so far.
When i had all of the switches pressed in at the top there was no hot water from the immersion once i turned the gas heating off downstairs overnight.
I believe the wire running from the lowest switch goes round the back and up to the inmersion at the top. This switch has 'off' written at the top.
I have attached a photo of how there switches were before i pressed them all in at the top. The switch right at the top can be ignored as it is for the garden light.
Thank you
Zak
Posted: Sun Oct 30, 2016 11:59 pm
by Zakjg
Also, I would have thought that when i had both switches pressed in at the top then the immersion would be on, as per ericmark's comments about non domestic switches being the reverse of a domestic switch.
As you can see from the attached photo, 'off' is written at the top. Does this mean that the switch is off when the switch sticks out (pushed down), rather than pushed in at the top?
Thank you
Zak
