How to Wire a Rotary Cam Switch HZ5B 10 Model
Posted: Tue Aug 08, 2017 6:24 pm
by arronston78
Hello. Hope someone can help me? I am trying to wire a rotary cam switch HZ5B 10 model. It's just a simple on / off I need connected to a lamp I am building from scratch. I'm not great with terminology so basic instructions would be great. Thanks in advance.
Re: How to Wire a Rotary Cam Switch HZ5B 10 Model
Posted: Tue Aug 08, 2017 9:49 pm
by Mr White
The cam switch you mention is for commercial use, why can you not use an ordinary switch?
What worries me is if it is for commercial use, you should not be connecting it.
Posted: Wed Aug 09, 2017 3:10 pm
by arronston78
Mr White wrote:The cam switch you mention is for commercial use, why can you not use an ordinary switch?
Hi. It's for a project. I'm building an industrial look lamp from an old 1950's amp meter. It already has an old cam switch but obviously not safe to use due to age and only need it to be on and off. The switch I'm looking at is for 240v use. I just want to use the original rotary knob but modernise the switch
Posted: Wed Aug 09, 2017 7:01 pm
by kbrownie
How does the instructions tell you to wire it up?
Posted: Wed Aug 09, 2017 7:59 pm
by Mr White
I would guess it does NOT come with instructions?
I think it would be best if you posted pictures.
Posted: Thu Aug 10, 2017 1:44 pm
by arronston78
It dudno come with instructions. But with some help from a mate and a 9v test circuit. I got it going!!
