Replacing Inline Extractor Fan Plus Light With Ceiling Fan Only
Posted: Sun Sep 10, 2017 9:33 pm
Hi there, first time post. Thanks for any help you can give.
My inline bathroom extractor fan is dead. It was one of these that came with a light: http://www.screwfix.com/p/manrose-in-li ... 00mm/41379.
I've replaced it with a regular ceiling mounted extractor fan without a light, with a timer and hydrostat. One of these: http://www.manrose.com/specifications/Quiet_Fan.pdf
I've wired the new fan using the Neutral (grey), but switching the Switched Live (Black) and Permanent Live (Brown) cables from the old fan.
The replacement extractor fan is working as designed...but in reverse. It turns off via the timer, when the light is on. When the light is turned off, it remains on continuously. It should be working the other way around.
It should be on continuously when the light is on ie your having a shower etc and it should turn off using the timer, when the light is switched off.
Right now it's working the other way around.
Any ideas how to fix this?
Has anyone had success replacing an in-line fan and light with a ceiling fan only? I'm beat!
