Light Switch no Longer Working After Wall Light Change
Posted: Wed Nov 08, 2017 8:12 pm
Hi.
I have two sets of lights in a room. Two wall lights operated by one switch and two ceiling lights operated by a separate switch. I changed the wall lights and they worked fine. I have since taken down one of the ceiling rose's and there were three separate cables each with L,N and E. Stupid me didn't note what went where. I have now put up the new rose and the light stays on permanently. The second ceiling light doesn't work at all (this only has the one feed to it). I believe I have identified which cable is the switch/live using a multimeter. I have swapped the wires around numerous times to test if any other combination works, however the current way I have them keeps the wall lights working. If I change it around, sometimes the wall lights dont work at all and sometimes all the lights flicker. Does anyone know what I have possibly got wrong? I have very basic knowledge of electrics but am a fairly competent DIY'er.
