Ceiling Rose Wiring to Power Second Light
Posted: Sat Nov 18, 2017 1:15 pm
by Jonathanhat
I am wanting to fit a second light with the power running from the existing rose, however the current wiring doesnt reflect diagrams i have seen. I have 3 completely seperate wires ...two neutral and one live. Any thoughts on this system...and do i simply take a feed from the N and L to. New box and so on?
Re: Ceiling Rose Wiring to Power Second Light
Posted: Sat Nov 18, 2017 8:47 pm
by chriscba
If you want the second light to come on with the existing light you can connect live and neutral from the two outer connections. The three lives in the middle are live in live out & live to the switch. The two neutrals are in & out. Black wire with red sleeve on is a switch wire, live return from switch
Posted: Sun Nov 19, 2017 12:47 am
by Mr White
If you want the new light to operate on / off the same time as the existing light then yes connect to the "Live and neutral" But you can only use a double insulated light as there is no earth (There is no earth shown in the picture)
If you want the new light to operate independently of the existing light then you cant as you only have neutral and switched live, you need neutral and permanent live.
