Broken Pendent Light Fitting When Changing Bulb
Posted: Mon Feb 12, 2018 8:29 pm
A Couple of questions.
My mother-in-law broken the lower part of a pendent light fitting when fitting a new bulb. It separated above the section holding the bayonet and exposed the brass screw connectors for the wiring to the bulb holder. She asked me to look at it and my feeling was that the plastic had cooked and gone brittle. When I looked at the bulb it was 100w in a 6" pendent fitting which I think it way over the top. I believe these fitting are limited to 60w or even 40w. The white shroud was also going brown at the edges a sure sign of excessive heat. There was no light shade fitted.
She has asked me if I can replace it. I am a competent DIY'er having updated and replaced sockets and light switches at home over the years all basic stuff, but I believe in this instance because it is not my property I cannot replace this pendent for her. I'm unclear on the laws regarding this and obviously 3rd party liability should a problem occur. The flat is old and the wiring not good, she also has the old fused consumer unit which I have suggested she get replaced on many an occasions.
Irrespective of the ability to do the job, I'm assuming I can't because of the legalities of it all.
I have already recommended she use a suitable LED bulb when the pendent is replaced.
