New Light Fitting to Replace Old Ceiling Rose
Posted: Sun Mar 18, 2018 7:07 pm
Hello, hope someone might be able to help?
I am replacing an old pendant with a new light fitting but have found the ceiling rose connector to be a bit strange.
I have connected the new light fitting to all possible connectors (Live & Neutral respectively) and found that the light switch will not operate and the light is always on.
The old pendant had blade style connectors that were part of the ceiling rose cover, these inserted into the middle connector slots (see pic). I am assuming that these are the only connectors that are operated by the light switch or am I missing something?
Do I need to use a different ceiling rose or can I wire the new light fitting into this somehow?
Thanks in advance
Thanks in advance
