Help With Wiring and Changing Light Switches for new
Posted: Mon Sep 24, 2018 11:36 pm
https://imgur.com/gallery/qzCXBmX
I have recently bought my first flat. As part of fixing it up I'm swapping light switches out for nicer ones. In the living room there are two separate light fittings at each end of the room. They were controlled by a single box, with 2 dimmer switches on the panel., Each switch controlled 1 light. So I could have both on, left on and right off, Right on and left off or both off. The first image in the IMGUR album shows how the dimmer box was wired (I can still track which wire was where).
I've decided to swap it out for a 2 gang, 2 way switch, with just an up and down (no dimmer). I tried putting wires in each common and L1, but this meant that only the left light would turn on. I've tried multiple other configurations, with no success. The current configuration is shown in the other 2 images in the album. This configuration results in both lights turning on and off, but only from the left switch, with the right switch doing nothing.
Any help to reestablishing independent control of each light would be greatly appreciated!
Many thanks
Many thanks
