Installing Wall Heater and Using Old Wall Light Wiring
Posted: Sat Sep 29, 2018 10:10 am
Quick question before I get a sparky out.
I currently have a wall light in my conservatory that we don't use as we have had a good conversion and downlights installed. The wall light is operated from a fuse switch in my living room which is located at the side of a single socket. The wall light is the only thing powered by this fuse switch. Having looked at the fuse is has a 13A fuse in the box so I am unsure whether the light was installed on the power circuit rather than the lighting circuit when it was first fitted. I am wanting to remove the wall light but want to install a wall heater and am hoping to use this circuit.
Is there a way to check whether the light is already on the power circuit and if it is would I be ok to install a 2kw heater onto it (keeping the 13A fuse)?
