Fitting Powerpoint into Stud Wall Opposite Existing Socket
Posted: Mon Oct 29, 2018 12:57 pm
by mheuter
Hello, i want to fit a new powerpoint into a false/stud wall in our house. there is already one on the other side of the wall, so i am thinking to pick up the cables required for the new powerpoint from the existing one (so this would be an extension of the existing one). Can I do that or is it a bit more complicated than that ...?
thanks,
Martin
Re: Fitting Powerpoint into Stud Wall Opposite Existing Socket
Posted: Mon Oct 29, 2018 7:50 pm
by Mr White
It depends on how it is currently wired, you do not give this information.
If it is on a ring I would split the ring between the old and new sockets, then to restore the ring install a new cable between the old and new socket.
Of course, you would have to prove it is on a ring first.
