Does this Nest Heat Link Wiring Look Right to you?
Posted: Mon Apr 08, 2019 11:18 pm
by jb123
Recently had Nest Heat Link installed by a pro but unfortunately it doesn’t work. The Heat Link doesn’t seem to communicate with the boiler. For example, boiler does not respond to Heat Link Manual Mode on/off.
Wanted to just quickly sense check the wiring with this forum and see if there’s anything wrong with it. Otherwise I think I need to call in another pro to look at the boiler. (I had the Nest installed because heating stopped working and a Worcester pro came over and concluded my thermostat receiver was faulty. Having switched the thermostat system and it still doesn’t work would make me think it’s actually the boiler being faulty).
Boiler is a Worcester Greenstar 24.
Heat Link:
N: connects to boiler N
L: connects to boiler L
2: leads nowhere
3: connects to boiler LR
Boiler’s Ls leads nowhere.
That’s it.
Attaching pictures of:
* an attempt at drawing it schematically. —o marks where the cable ends in empty space.
* how the wiring is supposed to be done according to the Nest manual (assuming my boiler is indeed a 230V Combi).
* photos of the wiring at Heat Link and Boiler connectors
Anything that looks wrong or is this definitely right? The Nest Pro installer seemed very knowledgeable but was a bit rushed.
Thank you!
Re: Does this Nest Heat Link Wiring Look Right to you?
Posted: Tue Apr 09, 2019 2:16 pm
It seems as if the link in Nest is missing, however Nest can be connected as OpenTherm but Bosch where there is access to boiler bus as far as I am aware has to use Wave as the boilers are not OpenTherm enabled.
Nest can be connected to boiler bus, or to 230 volt or to any other voltage i.e. 24 volt, there are loads of options.
I seem to remember the junction box in the Bosch is in a gas tight area, so I think to work on boiler side you have to be gas safe registered, personally think it is daft to put terminals in a sealed part of boiler.
However as far as I understand the Wave thermostat requires a large lump to be swapped in the boiler.
May be I should explain, years ago boilers and thermostats were digital i.e. either off or on, however a new boiler was designed which extracted more heat from gas called condensing, for this to work, the return water needs to be cool enough, so the boiler is designed to modulate, that is turn up and down, so it's output is between say 7 kW and 28 kW and originally this was controlled with the return water, and instead of wall thermostats we used thermostatic radiator valves (TRV) and the boiler sensed the temperature of the return water and turned up or down as required.
However once at 7 kW it could go no lower, so then started to switch off/on to control, and even in middle of summer it would continue to switch off/on. So we added a wall thermostat, often in the hall, to completely turn off boiler in the summer.
However as we progressed the idea of turning the boiler up/down electrically came in, so we swap the TRV heads with Nest to Energenie MiHome and these are either controlled by Nest or Nest controls the valve depends how set, then Nest with the OT1 and OT2 terminals tells boilers with OpenTherm to turn up/down.
With some the so called thermostat was really a hub reading the temperature in every room so each room can be a different temperature, the likes of Tado and Evo Home can be very complex and cleaver the way they control each room.
However as far as I am aware Bosch never signed into this system, they produced their own called Wave, however it only controls one room, so you have to adjust the lock shield on radiator to ensure that is last room to get hot, which seems daft as likely you went best control in your main room, so actually want that room to get warm first.
And it seems all the cheaper systems have some draw back, even with Nest and MiHome you can set the TRV head to be same as wall thermostat, but idea is you can have kitchen cooler than living room so you still end up with some fiddling to get each room the temperature required.
If you use off/on there is always some over shoot, or hysteresis as it's called, so thermostats started to include anti-hysteresis software, this turned boiler off/on before and after it gets to correct temperature altering as it is called the mark/space ratio. However when you turn the boiler off, any heat is sent out of the flue, so one you want the boiler as cool as possible before turning off, and two turn it off only when already at lowest output so switching off/on wastes energy, and can defeat the whole idea of condensing boilers.
However how much it saves or looses is unclear, the Energenie MiHome TRV heads and Nest can be set using GeoFencing i.e. turns off when is senses your phone has left the house and on again when it is within a set distance. However when I turned whole central heating off over night in heart of winter, in morning still at 17 deg C 8 hours latter, so with such a well insulated house is it worth it?
With oil central heating the boiler goes between 18 kW and 22 kW output and one has to ask was it really worth it? Yes ticks box as condensing boiler, but unlikely to really save much.
So do you just get extra wire added and boiler resealed, or do you install Wave instead, or simply use electronic TRV heads? If it was me, I would check boiler is 230 volt control, and if so just add the link wire.
Posted: Tue Apr 09, 2019 6:11 pm
by jb123
ericmark wrote:It seems as if the link in Nest is missing,
Thank you! Looking at what you wrote and doing a bit more research, I’m going to guess there’s a jumper wire missing between L and 2 (Common) on the Heat Link missing.
Do you agree with that assessment? And should one then just add a wire between the two?
Will probably call the engineer again though. Unless this is obviously the issue and something I can do.
Thank you
Posted: Wed Apr 10, 2019 12:44 am
My worry is it may be the 230 volt or the 24 volt control being used, and if 24 volt it could damage some thing fitting the link. However I am reasonable sure it is using 230 volt so yes likely only needs link, but I would always check and I can't be 100% from pictures.
Posted: Wed Apr 10, 2019 8:14 am
by jb123
ericmark wrote:My worry is it may be the 230 volt or the 24 volt control being used, and if 24 volt it could damage some thing fitting the link. However I am reasonable sure it is using 230 volt so yes likely only needs link, but I would always check and I can't be 100% from pictures.
I took a leap of faith (probably not advisable) and now it works perfectly. I also ran the suggestion through Newt customer service who agreed! Thank you very much. It was starting to get a bit cold...
