2 Gang Light Switch and Using the 2nd Switch
Posted: Wed Apr 17, 2019 8:18 pm
hello, i can hardley believe i havent been able to work this out by myself..... in my garage i have a 2 way 2 gang switch and a single gang at the other end of the garage.
so on the 2 gang switch only one side is used and it works no probs, i can switch the garage lights on/off from either end of the garage.
with the switch(gang) that is not used i'd like to connect it to my 12v transformer which will power my LED lights above my work bench.
so far i have tried every combination i can think of to get power to the trans. but nothing seems to work.
you can see from the image the first gang A is used and working. the second gang B is empty.
please help :-(
please help :-(
