Double Light Switch on/off Position Question
Posted: Sun Jan 12, 2020 6:39 pm
by Kathyfaull
We have just wired a new 1 way, 2 gang, switch plate, which works, but for one side the 'on' position is up, and for the other it's down, which looks odd and is impractical. Is this a problem with the new switch itself, or something we've done wrong?
Re: Double Light Switch on/off Position Question
Posted: Sun Jan 12, 2020 9:11 pm
by Mr White
I can't say I have heard of a 2 gang 1 way switch.
Are you sure you have not got a 2 gang 2 way switch?
Said switch is readily available and it would account for your "problem"
I will assume you do have a 2 gang 2 way switch it will have markings on the back which are either
C L1 L2
L1 L2 L3
Com One way 2 way
It matters not which you have. But you should make sure you have used the same identified terminals on each switch, so for the sake of argument C and L1 on each switch.
Unless of course you are using one switch as 2 way, say landing light, in which case, go upstairs and turn the light off from upstairs, then both down stairs switches will be the same.
Posted: Sun Jan 12, 2020 9:28 pm
by Kathyfaull
Thanks, have been unable to upload, but images are here:
https://diy.stackexchange.com/questions ... itch-issue
Thght it was 1 way bcs it was only switch that controlled that light. But probably i was confused!
Posted: Mon Jan 13, 2020 10:15 pm
by Kathyfaull
SOLVED: swapped one wire from L1 to L2 (which i hadnt used originally, because this switch is being used as a one-way (ie is the only switch controlling this light). But that worked.
