Help With Cutting for Knockout Boxes in Honeycomb Brick
Posted: Thu Feb 20, 2020 9:19 pm
Hi all, I'm getting stuck into renovating a mid 30s semi and installing knockout boxes. The whole house is made of hollow bricks, that are a bit like honeycombe when viewed from the top, except the holes are in straight lines.
Cutting out for knockout boxes is a nightmare as the bricks either disintegrate or just fall away in layers. I've tried using a bolster chisel so far and that hasn't worked. Don't dare try an sds on them. Drilling holes for the plugs for the screws is equally a nightmare as I just find a void and the drill wanders off.
Any advice on how to cut in for the boxes and drilling holes for the plugs and screws?
And what to do with the mess I've got so can install the boxes I've cut for so far. Any help much appreciated.
Image attached for example of what I've done so far.
