Low voltage garden lights using rubber cable
6 posts   •   Page 1 of 1
Stuart Davies
by Stuart Davies » Sun Apr 19, 2020 12:04 pm
Good afternoon , I’ve run 45 meters of 2.5 mm rubber cable round my garden for low voltage lights with 16. spurs , is this ok , thanks
Re: Low voltage garden lights using rubber cable
by stoneyboy » Mon Apr 20, 2020 11:03 pm
Hi Stuart Davies,
If you are installing a 12/24 volt system using led lights you will be ok.
Stuart Davies
by Stuart Davies » Mon Apr 20, 2020 11:11 pm
Excellent , thanks stoneyboy for your response.
Kind regards
Stuart Davies
kjones1829
by kjones1829 » Tue Apr 21, 2020 12:00 am
I agree with Stoneyboy! You will be fine if you used a 12/24 volt system with led lights. Just make sure that the cable has no physical damage.
Stuart Davies
by Stuart Davies » Tue Apr 21, 2020 9:08 am
Thanks kjones1829 for you response , will do as advised.
Kind regards
Stuart
kjones1829
by kjones1829 » Tue Apr 21, 2020 5:58 pm
You are very much welcome Stuart. I'm glad to help.
It is currently Sat Jan 11, 2025 6:17 am
