Low voltage garden lights using rubber cable
Posted: Sun Apr 19, 2020 12:04 pm
by Stuart Davies
Good afternoon , I’ve run 45 meters of 2.5 mm rubber cable round my garden for low voltage lights with 16. spurs , is this ok , thanks
Re: Low voltage garden lights using rubber cable
Posted: Mon Apr 20, 2020 11:03 pm
Hi Stuart Davies,
If you are installing a 12/24 volt system using led lights you will be ok.
Posted: Mon Apr 20, 2020 11:11 pm
by Stuart Davies
Excellent , thanks stoneyboy for your response.
Kind regards
Stuart Davies
Posted: Tue Apr 21, 2020 12:00 am
by kjones1829
I agree with Stoneyboy! You will be fine if you used a 12/24 volt system with led lights. Just make sure that the cable has no physical damage.
Posted: Tue Apr 21, 2020 9:08 am
by Stuart Davies
Thanks kjones1829 for you response , will do as advised.
Kind regards
Stuart
Posted: Tue Apr 21, 2020 5:58 pm
by kjones1829
You are very much welcome Stuart. I'm glad to help.
