Extension cable
greengrass
Extension cable
by greengrass » Fri May 29, 2020 8:17 am
need extension power cable 58 mt will this length cause power drop to effect use of ( a Garden vac (b Hedge cutter
many thanks
Re: Extension cable
by Mr White » Fri May 29, 2020 8:55 am
Voltage drop depends on the length AND size of the cable.
As for will it effect what you plug into it, that depends on the rating of what is plugged in.
It is not possible to be more specific as that is the only information provided.
Re: Extension cable
by ericmark » Fri May 29, 2020 10:23 am
Using 1.5 mm cable assuming 3 kW the volt drop will be around 21 volt, using 2.5 mm cable it will be around 12.5 volt, so it would need to be 2.5 mm cable, problem is getting 2.5 mm cable into a 13 amp plug is not easy, some makes will take it, but not all.
It is currently Sun Jan 26, 2025 10:11 pm
