2 way to 2 gang 2 way wiring for new light and switch
Msafti
by Msafti » Sun Nov 01, 2020 8:46 am
I currently have a two way switch supplying a light to a room, I'd like to add a second light to the room supplied by a second light switch.
The setup I want to end up with is for one light to be controlled by the current two way switch and replace the primary switch for the two way swit h with a two gang switch where the second gang controls a new light.
Can someone direct me to how to wire the second light please?
Re: 2 way to 2 gang 2 way wiring for new light and switch
by Mr White » Mon Nov 02, 2020 6:18 am
Since it depends on what colours and configuration you already have, you would be better off getting in a competent person to do to the job for you, that way they can see how it has been wired.
It is currently Fri Jan 10, 2025 11:04 pm
