Help with dimmer switch installation in kitchen
Posted: Wed Feb 24, 2021 5:31 pm
Hi guys,
First time poster - be kind.
I’m looking for some advice regarding a dimmer switch I have just installed in our kitchen.
We have a double switch which controls the kitchen and dining room on one side and a single which does the kitchen only.
I purchased a BG Electrical Single Dimmer Light Switch, Black Nickel, 2-Way, 400 Watts from Screwfix.
It was straightforward to fit but what I’ve found now is that the dimmer will only switch on/off when the kitchen double switch is on. You can then switch the dimmer on/off or adjust the brightness, but when the double switch is off you cannot use the dimmer to turn the light on.
I’ve attached some photos showing the double(white) wiring and the black (dimmer)
Any advice would be great.
Mrs is already doing my nut in!
