External light cables hanging from external wall for lights
Posted: Sat Feb 27, 2021 6:59 pm
by agtom
I have just moved into a house that on the external walls at the rear of the house there are 2 holes in the masonry one has one looped cable coming from it the other has two looped cables protruding from the hole. How do I go about wiring two walls lights into the two locations?
Re: External light cables hanging from external wall for lights
Posted: Sun Feb 28, 2021 12:07 am
by Mr White
It is down to the person who installed it as to the configuration they were thinking of, so with that in mind it will need to be tested to find out what does what and if anything is connected
I can only suggest you get a competent person in to do the job for you.
