How to wire 2 "smart" doorbells to the same chime?
Posted: Sat Aug 14, 2021 11:39 am
I have a Siemens Gigaset HC450 door intercom, installed with a Friedland D107 chime. The Siemens Control Unit is powered by a 12VAC 1A transformer, and the chime by an 8V 1A transformer.
I also have an Ezviz Smart Video Doorbell, powered by a 12VAC 1A transformer. I was wondering if it would be possible to connect this video doorbell to the same chime as the Siemens system, as the Friedland chime has 2 spare terminals - the Siemens system is connected to the 0(F) and 3(T) terminals, but the 1 & 2 terminals are unused.
Attached are the wiring diagrams for the two doorbells, and the same for the Friedland D107 chime which I'd like to connect the 2nd doorbell to. TBH I don't understand the difference between the two wiring examples in the Friedland D107 diagram.
Could anyone advise:
1. (How) can I connect the Ezviz video doorbell and transformer to the existing Siemens/Friedland setup
2. Should I retain separate 12VAC 1A transformers for the Siemens and Ezviz doorbells, or would it be feasible to power them both from the same transformer?
