Decommissioning hard-wired smoke alarms
Posted: Sat Feb 26, 2022 5:28 pm
Hi, apologies if this has been covered already, I couldn't find this scenario on the forums or anywhere else.
To comply with the new Scottish smoke alarm regulations, I am replacing my old hardwired smoke detectors with battery powered interlinked smoke and heat detectors.
My question is around how to decommission/disconnect the unused supplies to the old hardwired smoke detectors. I know I'm not supposed to just cap them and put them back in the hole, but a blank plate would look weird on the ceiling, and it's impractical to rip the wires out.
Luckily our fusebox has a separate circuit for the smoke detectors. Can I just disconnect this circuit from the fusebox, and if so, how? I'm guessing it's not sufficient to just leave the circuit breaker in the off position permanently and label it accordingly?
Attached picture shows opened fusebox with the smoke detector circuit breaker marked (this is labelled clearly on the outer casing of the fusebox).
Any advice appreciated. If it's not easy to do safely I will of course just get someone in but wanted to know my options. Thanks!
