Do I need thicker flex if making it longer?
Posted: Sun Mar 20, 2022 2:29 pm
I'm sitting up a load of LED lighting bars (2 different sizes) & they all come with the figure of 8 style flexes with moulded plugs that 1 metre long & are 0.5mm.
I was just about to swap these out 3 metre ones (0.5mm which I already have) then I thought I should check if I can stick to 0.5mm or would I need to buy something thicker? 3 metres seems nothing to me but I'm no sparky so thought I should check!
The larger units use around 60 watts & the transformer says "Output 21-33v 1200mA +3%".
Cheers!
Cheers!
