RCD protections with a FCU, what will paperwork tell me.
Posted: Thu Sep 14, 2023 11:01 pm
I think the electricians have made an error, I have had an UPS supply for central heating and three freezers, the latter has RCD type A sockets, but the boiler seems to still have the original switched FCU.
So is seems likely the boiler, pumps, motorised valves, and thermostats will have no RCD protection.
The earth rod was a very low reading of 0.37 ohms, I thought he was testing with the DNO earth connected, but no just the rod, so no problem that way.
However my worry is some plumber doing a service on the boiler switching off wrong FCU and getting a belt on a non RCD protected circuit, all the original were on RCBO's.
My RCD tester my son has, so the question is will paperwork show all the RCD's when SWA and RCD sockets are used? Will the paperwork make it obvious there is an error if there is one? Will it show two or three disconnection times on the paperwork, as all the paperwork I have used only has one slot for disconnection time per circuit.
It is enough to make some one travel 100 miles to fix? A RCD FCU is cheap enough, so swapping it not a problem, but should I touch their work.
It is notifiable work as all work done was either outside or in a kitchen, and I live in Wales.
