Car Port Lighting PIR 250w HELP!
Posted: Tue Oct 30, 2007 12:20 am
Hi Guys
Moved house,and my carport has the following:
Under the cannopy, there is 1x 250w PIR Light
Then, at the sides, well inside, there are two more lights but without the PIR.
The switch is for this is at the end of the carport, behind a metal box.
Problem is, when I turn them on, the PIR light , goes off after 4 minutes, but the other two 250w jobbies stay on.
Ive traced the cable, and its a kind of master / slave type thing.
Theres a 3 core cable, from the switch, to PIR 250w light, then out of here to the non PIR Light, then across to the next non PIR 250w light.
The fittings and cable are in good condition.Ive taken the back off the PIR Light and there are 2 cables, (of 3 core,),
any ideas of whats going on. Ive only noticed this since those clocks changed!!
Thanks in advance.!
Shaun
Thanks in advance.!
Shaun
