13A Sockets in Kitchen
soundtecuk
by soundtecuk » Wed Nov 14, 2007 6:49 pm
I'm currently having a new kitchen fitted and having my exsisting washing machine & Dryer hidden behind some doors.
My problems is that the electrician has put the sockets for these appliances in the adjacent cuboards with plastic back boxes ( they look a right mesS)
The Electrician says that this is common pratice, but if i want to change my dryer for a new one, i have to empty the adjacent cuboard, cut off the plug top a feed the cable through the underneath of the cabinet. then do the same with the new Dryer flex.
Can the socket for the dryer be installed at the back of or in the same cabinet as the dryer.? If isolated above or not even?
Also, is he allowed to install a 13A socket via a plastic or metal back box to the [b]wooded[/b] kitchen cabinet[i]
thanks for your help
[/i]
fridspark
by fridspark » Thu Nov 15, 2007 9:05 am
OK, if your appliance can be located less than 2M away from a switched fused spur then YES they can be located behind the appliances, what your electrician has done isn't wrong or right, everyone has there own views on the regs, at the end of the day if you can find a reason in the regs why not to have it installed the way he has done it then I may suggest getting someone else in to give you another view point on the matter then ask the person who has installed it to change it
It is currently Sun Nov 24, 2024 10:43 am
