cooker sockets
Posted: Mon Apr 02, 2007 8:05 pm
by pageantcd
Can I house a cooker socket for an induction hob and oven,in a base unit or does it have to be on the wall nearby.
Posted: Tue Apr 03, 2007 8:35 pm
regs only say 'readily accessable' BUT would you want to go into the base unit under a chip pan fire to isolate hob? which is why the cooker panel should not be placed behind the cooker/hob
Posted: Thu Apr 05, 2007 10:07 am
by pageantcd
[quote="sparx"]regs only say 'readily accessable' BUT would you want to go into the base unit under a chip pan fire to isolate hob? which is why the cooker panel should not be placed behind the cooker/hob[/quote]
Thanks Sparx, I will be putting it on the wall nearby.
