Wall Lights
Posted: Wed Nov 21, 2007 5:35 pm
I am about to install 4 wall lights in a room and take the power from the ceiling rose in the same room. I was going to place a 20 amp 6 terminal junction box in the ceiling space and connect each light seperatly from there, the same way as described here https://www.diydoctor.org.uk/projects/pr ... trical.htm
However someone has told me that this is not the best way to do it and I should connect each light in series with seperate cables running from light to light. Could someone tell me which is the best\correct way. :?:
thanks
thanks
