Fitting a wardrobe light
Posted: Wed Apr 04, 2007 10:57 am
by damian
Hi.
I would like to fit a light in to a built in wardrobe so the light comes on when you open the wardrobe door and am wondering where to get the power from.
The easiest way I can see to do it would be to go up in to the loft and tap in to the upstairs lighting circuit with a 3 terminal junction box.
Is this the way to do it or do I need to get the power from elsewhere?
Thank you very much for your help.
Kindest regards,
Damian Taylor
Posted: Thu Apr 05, 2007 2:20 pm
that is one aceptable way as long as you identify the live looping cable and not a switch wire!!!
the other way might be to go into ceiling rose , find live wires in loop-in term and neutrals going to blue of flex and connect there
SEE projects - adding a light
