Light permanently on-cannot switch from switch
Sparkydelux
by Sparkydelux » Sat Dec 01, 2007 6:03 pm
Just finished a new build house when my final item I had to do seemed to have taken away my glory of complete success.
I have an external light which is running off a JB (now concealed between new floor/carpet and a new cieling.I cannot get to it as you can imagine because the client has moved in and will not under go any further works.
I was certain I had done it all right but I must have been having a bad day.
Anyway,In a nut shell.Light outside is permanently on.I have 2 cables (initially for the switch) which are doing nothing.Tested the switch for voltage at both Phase and neutral to earth to see if there was some juice on them.Nothing.
So I have a light permanently on which cannot be switched,that I cannot access the JB and the client looking for an answer to resolve.
I've been scratching my head so much i'm virtually bald!!!!
Please could someone help me on a resolution or solution?
I have a last minute resort of using a lux level switch and PIR to switch the item on with movement but ultimately I'd like them to have control of the light where initially agreed.
I look forward to your response,
Regards.
by sparx » Sun Dec 02, 2007 9:54 am
Hi, now you know why regs state all screw connections must be available for inspection!, sorry but don't know easy way out
regards SParx
333rocky333
by 333rocky333 » Sun Dec 02, 2007 2:04 pm
where did you three plate the wiring in the light or the j/b.
If you have only took the live supply from the j/b and your saying the light is permenently on, then you will not need to access the j/b as the problem is elsewhere
where have you two wires doing nothing,do you mean there not connected.
why have you got a neutral at the switch are you wiring it double pole
It is currently Sun Jan 19, 2025 3:14 am
