Re-Wiring A House
Posted: Wed Jan 02, 2008 6:55 pm
by daryl
Hi All,
I have recently moved into old house and I need to replace all the electrics (junction boxes, wiring and fittings). As I am not a qualified electrician, and have a good understanding of what I am doing, am I able to do this and still comply to part b?
Posted: Wed Jan 02, 2008 11:31 pm
by BLAKEY1963
DARYL
get in a part p sparky to advise u.
BLAKEY1963
Posted: Thu Jan 03, 2008 7:25 pm
To the question is it possible then I must answer yes. But if the question is am I likely then I must answer no. If you do an internet hunt you will find part P can be down loaded and when you read what is required you will realize although you can do it the paper work requires readings from specialist meters and you need to fill this in yourself. The fact that it is filled in correctly is often taken as prof that you now what your doing but this varies area to area. Your best bet is to find an electrician who will allow you to labour for him. He tells you what he wants you to do before next visit. Although you may be able to rewire yourself I think you may find you ending up getting an electrician in the end anyway and cost you more money not less.
