under unit lights
prawnboy
under unit lights
by prawnboy » Mon Feb 04, 2008 6:15 pm
Forgive my ignorance,but i am a novice at electrics.Could anyone tell me how to wire low voltage lights.I have just moved into a 10 year old house and above each kitchen unit is a cable from the light, there is also a cable under each unit which emerges from the top of the unit as well.I would like to fit lights above and below the units,but how do i wire them?I presume the previous occupant intended to do the same but never finished the job. I have a 2 way switch already fitted,with one switch taped up ,presumably as when it is switched on the cables above the units are live.
BLAKEY1963
by BLAKEY1963 » Mon Feb 04, 2008 8:06 pm
prawnboy
obviously someone started this and left no deatails.
as work in a kitchen comes under part p , i would advise
you get in a part p sparky to advise u.
BLAKEY1963
It is currently Thu Jan 16, 2025 8:11 am
