When answering a question I get the following what should I do?
Could not insert new word matches
DEBUG MODE
INSERT INTO phpbb_search_wordmatch (post_id, word_id, title_match) SELECT 23921, word_id, 0 FROM phpbb_search_wordlist WHERE word_text IN ('earth', 'loop', 'impedance', 'resistence', 'measured', 'stop', 'current', 'flowing', 'short', 'circuit', 'ohms', 'live', 'called', 'mean', 'line', 'conductor', 'needs', 'special', 'meter', 'measures', 'calculates', 'parameters', 'displays', 'directly', 'plugs', '230', 'volt', 'supply', 'according', 'mcb’s', 'rcd’s', 'consumer', 'unit', 'below', 'set', 'figure', 'taken', 'table', 'example', 'biggest', 'mcb', 'b32a', '44', 'lower', 'required', 'furthest', 'socket', 'normally', 'power', 'one', 'continuity', 'again', 'means', 'basically', 'connected', 'low', 'ohm', 'ohmmeter', '200ma', 'e', 'multimeter', 'added', 'value', 'given', 'authority', 'give', 'final', 'talk', 'insulation', 'resistance', 'flow', 'likely', 'meg', 'controls', 'amount', 'leak', 'away', 'perfect', 'insulator', 'always', 'hope', 'excess', '1m', '937', 'uses', 'able', 'produce', '500', 'measurement', 'three', 'meters', 'last', 'two', 'same', 'duel', 'function', 'third', 'used', 'test', 'both', 'trip', 'first', 'measure', 'prospective')
Line : 251
File : functions_search.php
