Pulling Down Spotlights
Posted: Sat Feb 23, 2008 7:57 am
by jimboselecta
Hi all,
I've got a problem with my kitchen spotlights. There are 7 lights in my kitchen but at the moment only 2 of them are working.
I know that its a loose connection because i've switched the bulbs and also the other lights intermittently switch on every not and then.
My problem is that i can't get the things out if the ceiling. They seem to be held in by a spring, almost like a mouse trap but i can't get my hands in to release it!
Is there a trick to releasing these?
Many thanks in advance.
Posted: Sat Feb 23, 2008 8:43 pm
by kbrownie
jimboselecta,
If you take a good look you will see that the clip/springs are not totally round and should have a couple of tails pointing inwards to the centre of the light.
Pinch them together and pull gently down and clip/spring should become loose. The bulb will drop with a little help!
Regards
KB
Posted: Sat Feb 23, 2008 11:10 pm
Hi JIM, I think KB is telling how to remove glass front (if fitted) but I think you need to remove whole light from ceiling?
It requires nerve but just pull gently but firmly down until springs are visible, squeeze them tightly to the body of light & keep pulling down, as light clears ceiling they will spring outwards. to refit squeeze them against body of fitting and as soon as they are clear of top edge of ceiling should 'snap' back into place.
regards SPARX
Posted: Sun Feb 24, 2008 4:48 pm
by kbrownie
Sparx right, sorry was a long day. Didn't read post correctly.
KB
