Adding a Socket to a hollow wall?
Posted: Thu Mar 06, 2008 9:58 am
by pjames.79
Hi, Im looking for a bit of advice for putting in a new socket-
Id like it to go downstairs in the living room, there is a plug nearby already that I can run a spur off but the location I would like to put it in is hollow - in that its a 'blocked up' hole where the staircase used to be and is only a bit of plasterboard..
Is this possible still and is there some sort of special fitment Id need for the plug? All the info I can see so far is for the the socket boxes that need to be embedded into a wall (but i have no wall!)
Any advice much appreciated
Thank you, Paul.
Posted: Thu Mar 06, 2008 2:43 pm
by thedoctor
Hi, go to thi9s link for a mounting or "patress" box which is especially made for plasterboard walls. It is fitted from the outside and simply tightens up on the board as you screw in the face plate.
Posted: Thu Mar 06, 2008 3:39 pm
by pjames.79
Hi I'll have a look, thank you for your help!
Paul.
