concrete fence posts
Posted: Tue May 13, 2008 7:59 pm
by deleydeek
Could anybody help please.
How much below soil level does postmix have to be and what is the legal height that i can go.
cheers
Posted: Wed May 14, 2008 8:10 pm
by ALDA
D,
IN MY AREA OF THE COUNTRY, THE HEIGHT OF A FENCE IS LIMITED TO 2-METRES OR 6' 6" IN OLD MONEY.
ANY HIGHER AND PLANNING PERMISSION IS REQUIRED!
SO AN 8-FOOT POST WILL BE SUNK 1' 6" INTO HOLE AT LEAST TWICE AS WIDE AS THE POST AND SPACE BACK FILLED WITH THE POST MIX, TAMPED DOWN, SOAKED IN AND POST PLUMBED.
A.
Posted: Thu May 15, 2008 3:09 pm
by Gruff McStumble
I think concreate fence posts look a bit "council estate" dont you?
Posted: Fri May 16, 2008 8:52 pm
by døugie
Oh, I don't know, concrete is used in lots of places, not just by councils. I once saw concrete fence posts in the grounds of a stately home.
Fence Post Height
Posted: Tue Jun 17, 2008 2:15 pm
by kevin17
Just out of interest where is the 6 ft 6 ins measured from. The garden at the back has a raised patio area then there is a bit sunk by about a foot to take two filter chambers for a pond.
I take it I can make it 6' 6" from the patio area.
Posted: Sun Aug 24, 2008 10:01 am
by blademan
i have concrete post in my garden which i have put 6" exactly from my ground level not from any raised bits (shed base) which i also have i have 8" posts which are 2" foot in the ground and 2" gravel boards between each post i did a wet mix of concrete for the holes and covered with plastic untill set but i put the fence panels in on the gravel boards as i was going dont try to slide them in after from the top this is more difficult only the last one you have to do this
Posted: Wed Oct 01, 2008 4:57 pm
by scottglider
[quote="ALDA"]D,
A.[/quote] Hi, my neighbour has just erected a new fence using concrete posts. Looks OK however, I'm concerned the posts aren't deep enough? They are 8' posts, set 18" deep. The panel are 6'. This leaves 6" of post proud of the top of the panel. Also their is a hole in the post just clear of the top of the panel. What is this for, I'm guessing it may be for a secure bolt or something to stop the panels from being raised? If this is true then the posts must be at the right depth.
Explanations would be much appreciated as it really bugs me every time I look at it, I things done properly. :?
Posted: Sun Mar 08, 2009 10:37 pm
by 750dave
The hole At the top of a concrete fence post is usually used for a wire tie to support the top wire in a chain link fence, tho I have seen said top wire fed thrugh these holes but that seems rather a laborious way of going about it
