insulating concrete roof and single skin brick walls
Posted: Wed Jul 06, 2011 10:23 am
by slap2011
does any one no how to insulate a concrete roof internaly as i want to turn my shed in to another room and looking for advise on this one as it also tends to get damp in the winter as well and insulating a single skin brick wall as well any help please.
Posted: Thu Jul 07, 2011 3:43 pm
by sam0010
As you are looking at insulating internally (cold flat roof) you would need to provide some ventilation between the insulation and the concrete deck to remove any potential condensation build up. By fixing 50mm battens to the concrete you could then either use an insulated plasterboard or rigid board insulation to the underside. For the solid wall again an insulated plasterboard fixed to a minimum 25mm treated timber batten would do the job. Kingspan Insulations Kooltherm K18 maybe an option or the Thermapitch TP10.
concrete roof
Posted: Thu Jul 07, 2011 8:05 pm
by welsh brickie
you can fix 50x25mm thick tanalised battens and sprayfoam in between.sprayfoam is water resistant so it will eliminate damp bridging
Posted: Thu Jul 07, 2011 8:09 pm
by slap2011
hi sam0010
thanks for your reply and that sound like that will do the trick im new to this web site the mrs did not think it would work cheers mate
