Pooling Disguising With new Roof Balcony
Posted: Sat Jan 11, 2020 9:45 am
I have recently had a flat roof/balcony that is concrete but leaking, fibre glassed by a local company. They had good reviews on yell. They appeared to do everything correctly using OSB etc and the job looked good. However when it rained there was a lot of pooling due to what appeared to be a raising along the edge preventing water getting into the gutter. They promised to come back on numerous occasions to return and put more resin on to cure the problem but eventually did not reply to my email and texts. Your views on making the surface look better can I use lightweight promenade slabs fitted with adhesive, GRP slabs fitted on cement, pvc decking. The roof part is waterproof but the boss want it to look better!
