Best way to protect an old but apparently sound flat roof
Posted: Mon Sep 27, 2021 6:00 pm
I want to extend the life of an asphalt flat roof that will be 23 years old next month. There are no leaks in it, and cracks in the felt where it goes over the long edge of the roof were sealed last year with bituminous sealant.
Recently I noticed some cracks in the felt at the bottom of the upstands so I sealed them with scrim tape and Acrypol+. I also covered the earlier repairs with a coat of Acrypol+ as I had the tin open.
In order to facilitate inspection of the roof I swept up and removed the chippings that had been laid on the felt originally (along with the accumulation of moss, bird droppings, and general dirt), and discovered that a substantial amount of them had become embedded in the roofing material.
My question is: How should I proceed, in order to further extend the life of the roof? The embedded chippings make covering the roof with Acrypol impracticable, and I've no desire to start scraping them off.
Would flooding the roof with a suitable material be a reasonable approach? If so, what should I use? Or would simply replacing the old grey chippings with more reflective ones be adequate?
I would add that there are no spongy or saggy areas on the roof; I can walk on any part of it without feeling as though I'm going to drop in unexpectedly.
The object of the exercise is to head off trouble at the pass and not to repair existing leaks, because there aren't any.
