Concrete floors
Posted: Fri May 26, 2006 3:32 pm
by thedoctor
To post a question for a Diy Doctor tradesman or your fellow users, to answer please click on “New Topicâ€
Posted: Mon Mar 12, 2007 12:59 pm
by bob the bodger
I'm intending to incoroporate an outhouse into the main property. It already has a concrete floor -unsure of whether there is any damp proofing below. I need to raise the floor by 200mm to bring it level with the main building and obviosly incorporate a damp proof membrane. Are they any alternatives to pouring in 200mm of concrete. Should the membrane be incorporated into the be on top of the existing floor with the concrete or alternative infill above it ?
Posted: Thu Mar 15, 2007 7:02 pm
by mikester
You can get insulation boards from your local builders merchant that are for this. I think they are about 2inch thick but I don't see why you can't use more than one layer, just lay couple inches concrete or screed on the top. The boards double up as damp proofing (you will probably need some kind of DPM in the walls as well though. Can't remeber the name of the product I know Jewson sell it though.
Posted: Thu Mar 15, 2007 7:06 pm
by mikester
You can insulation boards from Jewson that can be used for this, Just pack up to the required height and put a couple of inches of concrete or screed over the top. They meet regs for DPM so no need for a separate on, should help keep the room warm too.
Posted: Fri Mar 16, 2007 1:12 pm
by thedoctor
MANY OF THE ANSWERS TO YOUR POSTS CAN BE FOUND, WITH DIAGRAMS, IN THE DIYDOCTOR PROJECTS SECTION. CLICK HERE www.diydoctor.org.uk/projects.htm
