Renovating a granwood floor
Posted: Sun Mar 08, 2009 11:25 am
by richard_white_bsc
My kitchen and hall has granwood tiles that are in a poor condition - they are worn and discoloured. I would like to sand and seal them but have been unable to find much DIY advice since granwood floors appear uncommon in domestic residences. I know I can hire floor sanders (I sanded the wooden floor in our lounge) but I'm not sure what abrasive to use - granwood is very hard. I would also like advice on what to use to seal the surface after sanding and what to use for subsequent cleaning and polishing, bearing in mind the locations. Are there any granwood experts out there who could help?
Posted: Mon Mar 09, 2009 6:41 pm
by Tall Tone
Be very careful here.
Granwood is a mixture of concrete and wood and as such, when you sand it you get very fine concrete dust floating in the atmosphere which is a bit like a thick fog, but is also very bad for your lungs.
If you decide to proceed any further you need a very good mask/respirator and a way of sealing off the room so you minimise clean down afterwards.
Due to the waxy content of the floor the only lacquer suitable is Granguard, which if memory serves is a very smelly solvent based product.
Personally I would suggest this is one for an expert with the right equipment.
Regards
TT
