Carpet cleaning...
Posted: Fri Sep 18, 2009 12:11 pm
by Adwer
You can steam clean your carpet with little or no cleaners provided you pretreat any stains before you start. Shampoos and foam cleaners tend to leave a residue which in turn will attract dirt again. Good luck.
Posted: Sat Apr 09, 2011 7:29 am
by jennyj
Has anyone had to try to get candle wax out of carpet? Will a regular carpet cleaning service be able to do it?
One of the function rooms at work has dark blue carpet, and blotches of white candle wax EVERYWHERE!!!
Posted: Thu Apr 28, 2011 3:33 pm
by christatedavies
Put a sheet or two of kitchen roll over a patch of wax, and iron it. This will melt the wax, and the kitchen roll should soak it up. You might have to do it a few times depending on the extent of the spillage.
I have done it before with good results.
Posted: Wed Jun 15, 2011 8:38 pm
by manandvan
Have any suggestion how to i get rid off curry colors from white carpet?
Posted: Fri Jun 24, 2011 6:58 am
by Roben
If its plain white you can just bleach the stain out. Just use chlorine bleach. If your afraid to use bleach you can use oxy clean or chlorox 2. Oxy clean removed wine stains of my dad's shirt without damaging the color or texture at all. This will only work if your "jumper" is made out of a fabric though, hope this helps.
Posted: Thu Aug 11, 2011 5:55 pm
by wilsonjohn
What is the name of this method. Is it popular for cleaning carpet.
